Proxy & Cache
Hi to all, i need a little help about Proxy cache, Proxy not caching amd- ati website and do not cache drivers i download like from other sites. If someone knows the solution ?
I set Proxy max. object cache size to 5GB
X86 System Router OS 6.12
Change to Nvidia chipset!
Seriously…
You cache on memory or on disk?
Some particular type of download can be done once, the “file-name” identifier can change everytime, and the file downloaded from https are not cacheable.
Try this:
http://www2.ati.com/drivers/14-4-win7-win8-win8.1-64-dd-ccc-whql.exe
You expect to download the exe, but the site not find the right to allow you download this file…
We’re sorry, but we were unable to complete your download. There could be several reasons for this:
You were linked to this download from a site outside of AMD.com
Since we do not allow downloads through sites outside of AMD.com, please download your file directly from our site. We want to make sure you have the right driver for your device and operating system. Choose your product and operating system on the AMD Driver Download page or use the AMD Driver Autodetect to obtain the correct driver for your device.
You copy and pasted the download link or clicked “Save As”
When you copy and paste a link or right click on it and select “Save As,” your browser will not send a referrer and our site will not allow the download. Please click the Back button in your browser and simply click the link instead.
Either a browser or firewall is set to disable sending referrers
Many browsers and personal firewalls allow you to hide the referrer sending. If you have changed this setting, please change it back to allow referrer checking.
You’re using a download manager
Change the settings in your download manager to send an HTTP referrer so that we can verify that you are using our site for the download.
I cache on disk , (500 GB hdd ) I tried to download driver from that link http://www2.ati.com … And I download driver but that driver is not in cache, for example I download ubuntu and 600 mb iso remain in cache, but any driver I download from AMD not remain in cache
Sent from my HTC One using Tapatalk
You should also check the http header from the sites:
To see the if there are some no-cache
http://www.mobify.com/blog/beginners-guide-to-http-cache-headers/
curl --head http://www2.ati.com/drivers/14-4-win7-win8-win8.1-64-dd-ccc-whql.exe
[root@alarm /]# curl --head http://www2.ati.com/drivers/14-4-win7-win8-win8.1-64-dd-ccc-whql.exe
HTTP/1.1 302 Moved Temporarily
Server: AkamaiGHost
Content-Length: 0
Location: http://support.amd.com/en-us/download/incomplete
Date: Sun, 11 May 2014 20:13:18 GMT
Connection: keep-alive[root@alarm /]# curl --head http://www2.ati.com/drivers/14-4-win7-win8-win8.1-64-dd-ccc-whql.exe
I log Proxy cache for amd website a get this, in part of the log is ( Cache-Control: no-cache… ). Is that means that Proxy can not cache that site… ?
May/12/2014 00:04:45 web-proxy,debug Response to "GET http://metrics.amd.com/b/ss/amdvsupport,amdvglobal/1/JS-1.2.4/s57711659171310?AQB=1&ndh=1&t=12%2F4%2F2014%200%3A4%3A43%201%20-120&fid=246B46F0B1ACF461-3FB7A1D8F5B61BC9&ce=UTF-8&ns=amd&pageName=%2Fsupport.amd.com%2Fen-us%2Fdownload%2Fdeskto
May/12/2014 00:04:45 web-proxy,debug p&g=http%3A%2F%2Fsupport.amd.com%2Fen-us%2Fdownload%2Fdesktop%3Fos%3Dwindows%2B7%2B-%2B64&cc=USD&pe=lnk_d&pev1=%2Fwww2.ati.com%2Fdrivers%2F14-4-win7-win8-win8.1-64-dd-ccc-whql.exe&pev2=DD%7CGPU-Other%7C14-4-win7-win8-win8.1-64-dd-ccc-whql.exe&pid=%2Fsuppor
May/12/2014 00:04:45 web-proxy,debug t.amd.com%2Fen-us%2Fdownload%2Fdesktop&pidt=1&oid=http%3A%2F%2Fwww2.ati.com%2Fdrivers%2F14-4-win7-win8-win8.1-64-dd-ccc-whql.exe&ot=A&oi=952&events=event6%2Cevent15&v6=%2Fwww2.ati.com%2Fdrivers%2F14-4-win7-win8-win8.1-64-dd-ccc-whql.exe&c12=%2Fsupport.amd.
May/12/2014 00:04:45 web-proxy,debug com%2Fen-us%2Fdownload%2Fdesktop&c13=DD%7CGPU-Other%7C14-4-win7-win8-win8.1-64-dd-ccc-whql.exe&v13=DD%7CGPU-Other%7C14-4-win7-win8-win8.1-64-dd-ccc-whql.exe&c14=%2Fwww2.ati.com%2Fdrivers%2F14-4-win7-win8-win8.1-64-dd-ccc-whql.exe&v20=NA%2CNA%2CCV%7CDD%2CNA
May/12/2014 00:04:45 web-proxy,debug %2CNA%2CCV%7CDD%2CNA%2CCV%7CDD%2CNA%2CNA%2CCV%7CDD%2CNA%2CCV%7CAD%2CCV%7CDD%2CCV%7CDD%2CNA%2CCV%7CDD%2CNA%2CCV%7CDD%2CNA%2CLS%2CNA%2CCV%7CDD%2CCV%7CDD&c25=amdvsupport%2Camdvglobal&c41=Mozilla%2F5.0%20%28compatible%3B%20MSIE%2010.0%3B%20Windows%20NT%206.3%3
May/12/2014 00:04:45 web-proxy,debug B%20WOW64%3B%20Trident%2F7.0%3B%20.NET4.0E%3B%20.NET4.0C%3B%20.NET%20CLR%203.5.30729%3B%20.NET%20CLR%202.0.50727%3B%20.NET%20CLR%203.0.30729%29&v41=desktop&v42=large&v43=1576x768&c53=%2Fsupport.amd.com%2Fen-us%2Fdownload%2Fdesktop&v57=LS&s=1920x1080&c=24&j
May/12/2014 00:04:45 web-proxy,debug =1.6&v=Y&k=Y&bw=1576&bh=768&ct=lan&AQE=1":
May/12/2014 00:04:45 web-proxy,debug     HTTP/1.1 200 OK
May/12/2014 00:04:45 web-proxy,debug     Date: Sun, 11 May 2014 22:04:50 GMT
May/12/2014 00:04:45 web-proxy,debug     Server: Omniture DC/2.0.0
May/12/2014 00:04:45 web-proxy,debug     Access-Control-Allow-Origin: *
May/12/2014 00:04:45 web-proxy,debug     Set-Cookie: s_vi=[CS]v1|29B6644C851D3341-40000117E00032F9[CE]; Expires=Tue, 10 May 2016 22:04:50 GMT; Domain=.amd.com; Path=/
May/12/2014 00:04:45 web-proxy,debug     X-C: ms-4.8.2
May/12/2014 00:04:45 web-proxy,debug     Expires: Sat, 10 May 2014 22:04:50 GMT
May/12/2014 00:04:45 web-proxy,debug     Last-Modified: Mon, 12 May 2014 22:04:50 GMT
May/12/2014 00:04:45 web-proxy,debug     Cache-Control: no-cache, no-store, max-age=0, no-transform, private
May/12/2014 00:04:45 web-proxy,debug     Pragma: no-cache
May/12/2014 00:04:45 web-proxy,debug     ETag: "536FF402-6749-17F2624D"
May/12/2014 00:04:45 web-proxy,debug     Vary: *
May/12/2014 00:04:45 web-proxy,debug     P3P: policyref="/w3c/p3p.xml", CP="NOI DSP COR NID PSA OUR IND COM NAV STA"
May/12/2014 00:04:45 web-proxy,debug     xserver: www404
May/12/2014 00:04:45 web-proxy,debug     Content-Length: 43
May/12/2014 00:04:45 web-proxy,debug     Content-Type: image/gif
May/12/2014 00:04:45 web-proxy,debug Response to "GET http://www2.ati.com/drivers/14-4-win7-win8-win8.1-64-dd-ccc-whql.exe":
May/12/2014 00:04:45 web-proxy,debug     Server: Apache
May/12/2014 00:04:45 web-proxy,debug     Accept-Ranges: bytes
May/12/2014 00:04:45 web-proxy,debug     Content-Type: application/octet-stream
May/12/2014 00:04:45 web-proxy,debug     Last-Modified: Wed, 30 Apr 2014 14:13:50 GMT
May/12/2014 00:04:45 web-proxy,debug     ETag: "2fe848697bf1f8f0a8764584286e5bde:1398867230"
May/12/2014 00:04:45 web-proxy,debug     Content-Length: 269338400
May/12/2014 00:04:45 web-proxy,debug     Date: Sun, 11 May 2014 22:04:51 GMT
How can i cofigure mikrotik proxy to ignore no-cache heders , no-store… ?
You can’t…
