Proxy, Hotspot and Microsoft Update.
My Proxy Server is independant of the Gateway and was ROS v3.0RC4.
Have updated to ROS v3.0RC5 with the same results.
My APs (ROS v2.9.46) Server Profile defines the Proxy server address and port.
My clients cannot get there upgrades through Microsoft Update.
I have machines attached which do not go through the hotspot but do have the proxy settings defined whithin IE, and
Microsoft update works fine.
Anybody else have this problem?
HTTPS also works fine from the hotspot.
It appears to be a hotspot issue.
It would appear that any site that has a page with an ASPX extension potentially has a problem.
Windows Update never works, while other sites with aspx extension may or may not work.
Any other site has been no problem.
Can somebody verify this?!?
bump
there where problems with windows update before - as a workaround was suggested to allow connections to MS update service without proxy (if you search for topics you could find exact problem and solutions)
So you are telling me I have to do this for every site that uses active server pages?
What kind of solution is that?!?
If I can not access pages which have aspx extensions through the proxy, then what good is the proxy?
I would appreciate a proper answer…
