I ordered a routerBoard 493g, but I got a 450G while waiting for the other product to get here !
I never thought I would LOVE a router/firewall that much, i will never get back to other products
Well, I only have 1 concern, there is a proxy setting in the router that can cache all the web site we go to, and can also block entered web sites.
If I activate that, even without caching, my internet become really slow !
I am on fiber at 100mb/s on the internet, and I get 75Mb/s on speedtest.net with a latency between 0 and 7ms.
Proxy activated without caching just blocking *porn per example, then I have a latency of 207ms and 5Mb/s !
Am I doing something wrong or it is completly normal ?
Or will it be ok when iāll get my 493g ?
Well in fact, I just did some tests and the problem is not from webProxy !!
I have read somewhere on the forum that to activate the web proxy correctly, I should add a firewall filter Rule and a Nat rule !
Filter rule:
Chaine = Input
SRC= 0.0.0.0/0
Protocal= TCP
DST Port= 8080
In. Interface= ETH1-WAN
DROP !
NAT rule:
Chain = DSTnat
Protocol = TCP
Dst Port= 80
dst-nat to adresses x.x.x.x (Routeur IP Adress)
to port= 8080
The Nat rule seams to redirect the port 80 to 8080 because the WebProxy is configured to 8080 only by default, but I also added 80 in the webproxy !
And if I remove only that NAT rule, everything is OK.
I guess I donāt really need it ?
Ok I get it !!
The NAT rule is to redirect to the routerās proxy !
and if I redirect from port 80 to 80, every site goes to the routeur web access !!
So I still need some help on how to configure correctly without loosing so much speed !
I have found the same thing on my 450. As soon as I turn on the webproxy and then redirect to it jump from 4 to 5 ms pings to 250 to 260ms ping times. Surfing seems fast, but the latency sure seems high. I use webproxy for page logging purposes so I hate to have it turned off all the time.
I have the same issue on my 450, I also can get it to do it on a i386 machine. Any ideas on how to get this fixed. I see 26ms pings with webproxy off and 250 on. Any traffic hitting the proxy gets slowed badly. I set my rules to avoid my connection using a not 10.0.1.x. once the traffic avoids the proxy itās great.
I have seen this rule + the one in my previous post to really slow down the INet. The one in my previous post has been effective when I have not used proxy, and this last one when I have been using proxy.
I still ahve this issue on my 450g, even with all the suggestions in place. My CPU util is less than 40% but my latency is in teh 250ās with webproxy on and in the 40ās without.
Hm ā¦
Im also runing web proxy on X86 ROS 5.20 and can confirm that ping is going high
when firewall rule redirect to proxy : PING 150-200 ,
when I just disable firewall transparent proxy PING is 50 -60
But this is only seen on http://www.speedtest.net/
Ordinary ping to some host on internet is same ā¦
Yes I know that
I say that this āproxy issueā is only show in web when testing on speedtest.net ⦠i dont know why ⦠but im suspecting on speedtest.net script ⦠not on mikrotik proxy
