Proxy on Mikrotik version 2.9.11
Previously, my mikrotik was running on v2.9.6. I enable web-proxy on it. However, i encountered some problems when using the web-proxy. It seems that my web-proxy was not fully functionally.
i tried to upgrade my mikrotik to v2.9.11 then i installed the web-proxy test on my mikrotik. When i upgrade to v2.9.11, i see that ip web-proxy is no more available. it is changed to ip proxy.
so my question is: is ip proxy on mikrotik 2.9.11 is the same as ip web-proxy on mikrotik 2.9.6? in the manual, ip web-proxy performs internet object cache function whereas ip proxy perfoms proxying of HTTP and HTTP-proxy requests; it does no support caching transactions.
so how can i enable web-proxy on 2.9.11? i want to increase speed of web-browsing for my clients. and how can i use the web-proxy test package using 2.9.11?
thanks
i tried enabling ip proxy on mikrotik v2.9.11 just now…this is how it looks like:
                    enabled: yes
                      ports: 8080
               parent-proxy: 0.0.0.0:0
  maximal-client-connecions: 1000
  maximal-server-connectons: 1000
        cache-administrator: "webmaster"
            max-object-size: 87885KiB
        max-disk-cache-size: 70866000KiB
         max-ram-cache-size: 175770KiB
              disk-database: yes
then i add this:
 chain=dstnat protocol=tcp dst-port=80 action=redirect to-ports=8080
but then when i tried to browse the internet..it becomes so slow. why it becomes slower?
I have 2.9.11 MT and web proxy work very well. But ip proxy not
ip web-proxy> pr
enabled: yes
src-address: 0.0.0.0
port: 8080
hostname: “mendi”
transparent-proxy: yes
cache-administrator: “webmaster”
max-object-size: 128000KiB
cache-drive: system
max-cache-size: 1800000KiB
max-ram-cache-size: unlimited
status: running
reserved-for-cache: 1799168KiB
reserved-for-ram-cache: 8192KiB
In licence Level 5 ip web-proxy doesn´t appere as option.
May we enable this option via web-proxy test package?
I have the same problem…
web is very slow if the proxy is turn on
I will try in web-proxy…
status: running
uptime: 14h44m51s
clients: 38
requests: 69478
hits: 21985
cache-size: 1618264KiB
ram-storage-size: 8136KiB
received-from-servers: 315675KiB
sent-to-clients: 425559KiB
hits-sent-to-clients: 113652KiB
The status it’s ok, but in my router dont work.
This router was work nice in 2.8.5
I upgrade the router to 2.9.11 and proxy don’t work.
I will try to reset the router and setting from zero.
I found the “problem”
dst. limit rate 0/sec
burst 5
limit by:dst. address
Expire:1000ms
some rules in firewall was imported with this setting from 2.8.9 to 2.9.11
