When running a hotspot and a normal network of the same RB how do you config the proxy?
I want the hotsot to have full access to the net but the other network I want to limit using the proxy. Would you change the NAT rule so as to only redirect IP addresses on the local network (not hotspot) to the proxy?
Gromit, your rule should work, but you have to place it to the top of NAT rules.
As well you have to be aware of the fact, that reboot will bring dynamic HotSpot rules to the top. So you need to set script that will bring static DST-NAT rule to the top of the list.
I got it to work. I created an address list with the IP range of the IPs needing to be redirected to the proxy. The created an NAT rule using the address list.
