Proxy-test 2.9.44
Has anyone had any luck getting this to work? I have not.
Can someone post an example of a working config they have?
Thanks!
Could you be more specific about the problems with the proxy ?
under the status → lookups it says “non cacheable” and all the requests are there. it doesnt appear to cache anything
post your full configuration of it
ip proxy print
enabled: yes
src-address: 0.0.0.0
port: 8080
parent-proxy: 0.0.0.0:0
cache-drive: system
cache-administrator: “webmaster”
max-disk-cache-size: 1531440KiB
max-ram-cache-size: 150030KiB
cache-only-on-disk: no
maximal-client-connections: 1000
maximal-server-connections: 1000
max-object-size: 4096KiB
max-fresh-time: 3d
ip firewall nat print
chain=dstnat action=redirect to-ports=8080 in-interface=PPPoE
dst-port=80 protocol=tcp
i think thats everything yes? i want it to behave as a transparent proxy. The documentation on the MT site doesn’t quite cover each function of the new test package (obviously)
what do you have in “access” “direct” and “cache” menus?
i have the range for our local lan set to allow, and nothing in the rest of them aside from defaults
