my does my proxy upload so much
i see many connectionf from the outside how can i fix this
do i just allow port 80 or how can i do this?
You didn’t provide any info about your setup.
If you’re using a mikrotik box, you need to prevent open proxy with a filter rule.
Something like: /ip firewall filter add in-interface=wan dst-port=proxy-port protocol=tcp action=drop
I’m not clear on what you mean. Upload to your clients or upload to the internet?
oh sorry
yes im useing mikrotik box and i wanted to see why it uplods so much to the net?
so somthing like this with my 3 internet lines
add action=drop chain=input comment=“” disabled=no dst-port=8001
in-interface=ether1 protocol=tcp
in-interface=ether2 protocol=tcp
in-interface=ether3 protocol=tcp
That’s right.
Otherwise if you’ve got just one local interface then a single rule should do:
