Proxy v 3.x cache size
Dear all,
Anybody know the max size cache of secondary master? if i have 2 hdd, and the i choose the secondary master?? cause i have tried 30gb and it worked, but i tried with 80gb it didin’t work, always asked to format the disk first.
Please advice…
Thx,
Ferry
There should no be any limit. Perhaps 80 GB drive didn’t have proper filesystem.
Do you have any problems to get it work after format ?
so i must format with fat or ntfs? in order to be known in mikrotik? cause if i format with fat, the problem is still appear.. thx
You don’t need to think about format in NTFS or FAT.
Add secondary drive to your router,
ip proxy format-drive should make all things for you.
