Proxylizer doesn't gets log
I found several posts about this in forum, but nothing haven’t help me yet.
So I decide to open new topic with all images from my configuration.
I use RouterOS 4.5 on RB433AH. VMware server is on Win 2k3 server.
My problem is that my proxylizer works but I don’t get logs. It look only one record is in DB, but I know for sure that I and my other users made several hundreds domains.
This is what I get in proxylizer (VMware image used)
Now, this are my web proxy config:
General:
Status:
Lookups:
Inserts:
Refreshes:
I found this rule (it must be default):
and something in cache. I’m not sure what is this:
Here is NAT rule:
General:
and Action:
Finaly this is Logging rule for web proxy (as it sais in help)
And Log action:
Sorry for big post, hope you’ll find easier my error from this images.
Thanks in advance.
So, nobody can’t help? :frowning:
Yeah I had similar problems. I am not sure if it is a configuration with the VM image I had used or what, but I was not able to get the proxylizer to work either. I think I am a functional non-int at times but I got stuck and I had pretty much the same amount of posts as you did on this subject. Perhaps they could have a better or more upto date step by step post on this for people like me.
Sorry I could not be of any help.
-Sincerely,
DesertAdmin
Are you able to ping the proxylizer VM address from your MT? You prolly have the firewalling off but sometimes it does do its own VM addressing scheme; in that case I think you have to placve the VM into a bridge mode. Just a thought.
-Sincerely,
DesertAdmin
i beleive your problem is with your vm and not with the mt…
WTF?.. why src-port=80? it should be dst-port=80!
