Proxylizer + VMWARE vSphere
Проблема с конвертацией образа Proxylizer image (debian) под VMWARE vSphere 5.1
“C:\Program Files\VMware\VMware OVF Tool\ovftool.exe” “E:\Virtual Machines\Proxylizer image (debian)\Proxylizer image (debian).vmx” “E:\Virtual Machines\Proxylizer\Proxylizer.ovf”
http://www.mikrotik.com/download/proxylizer_vmware_image.zip
Пишет проблемы с виртуальным диском
При попытке импорта под VMWARE vSphere 5.1 Выдает такую ошибку
Power On virtual machine
File [RAID1_01HDD] Proxylizer
image (debian)/Proxylizer image
(debian).vmdk was not found
View details…
root
25.06.2013 12:36:47
Cannot open the disk ‘/vmfs/volumes/5135b63d-e3b5a081-e330-3085a9a66dd1/Proxylizer image (debian)/Proxylizer image (debian).vmdk’ or one of the snapshot disks it depends on.
The system cannot find the file specified
VMware ESX cannot find the virtual disk “/vmfs/volumes/5135b63d-e3b5a081-e330-3085a9a66dd1/Proxylizer image (debian)/Proxylizer image (debian).vmdk”. Verify the path is valid and try again.
it was created using older vmware. try to convert it or import it. Maybe something has changed.
Тест показал, что работает только на vmware server 2 for windows, конвертировать так и не удалось.
it was created with vmware server. but as far as i have used, they can be converted to other types of “disk images” and back again. Anyway, inside the image file is simple debian installation with proxylizer configured. You should be able to convert it to plain disk image file and mount it on loop device (in linux) and read all the data from it.
It is provided as an image only for ease of use.
тоже помучился… с готовым образом под esxi 5.0 в итоге толку ноль.
создал новую ВМ, и поставил по мануалу на основе ubuntu 12.04.
Если надо - могу попробовать выгрузить ВМ.
Да желателько, а то времени нет попробовать…
