Problem: mikrotik don’t want to save cache files in Proxy server on his ROM(30GB). But he successfully save on his RAM(when cache-on-disk: no) that is 1GB
Scenario:
CHR config is almost clean, just default gateway and enabled proxy.
I use KVM on CentOS 7:
[root@TOTORO ~]# rpm -qa |grep qemu
qemu-guest-agent-2.3.0-4.el7.x86_64
qemu-kvm-1.5.3-105.el7_2.4.x86_64
libvirt-daemon-driver-qemu-1.2.17-13.el7_2.4.x86_64
qemu-img-1.5.3-105.el7_2.4.x86_64
qemu-kvm-common-1.5.3-105.el7_2.4.x86_64
ipxe-roms-qemu-20130517-8.gitc4bce43.el7_2.1.noarch
[admin@MikroTik] > system resource print
uptime: 1h5m41s
version: 6.34.6 (bugfix)
build-time: Jun/06/2016 08:37:27
free-memory: 627.6MiB
total-memory: 1001.0MiB
cpu: Intel
cpu-count: 1
cpu-frequency: 3411MHz
cpu-load: 1%
free-hdd-space: 29.8GiB
total-hdd-space: 29.9GiB
write-sect-since-reboot: 640
write-sect-total: 641
architecture-name: x86_64
board-name: CHR
platform: MikroTik
[admin@MikroTik] > ip proxy print
enabled: yes
src-address: ::
port: 8080
anonymous: yes
parent-proxy: ::
parent-proxy-port: 0
cache-administrator:
max-cache-size: unlimited
max-cache-object-size: 504800KiB
cache-on-disk: yes
max-client-connections: 600
max-server-connections: 600
max-fresh-time: 3d
serialize-connections: no
always-from-cache: no
cache-hit-dscp: 4
cache-path: web-proxy
