I’m having some issues with my connection from PS4 > playstation network this isn’t working randomly.
If i restart the router, connection to playstation network is working. I can’t do this everytime someone whats to play on the PS4.
I don’t really know what changed, because it worked till the last two weeks.
Current configuration is PS4 behind router mikrotik with static public IP. and UPnP activated.
RB951G-2HnD
build 6.38.1
Please advice if someone has this problem
Read on forum already the posts with ps4 problems.
I have no problems with my PS4 and no special config on the MT for the PS4 either.
Also UPnP was off by default and I left it off and PS4 working fine.
Have you tried switching off UPnP?
Ok… i don’t know what is happening but it’s getting on my nerves.
What i did till now:
Disabled uPnP
Had it on DHCP, disabled,reenable
Enabled uPnP, tried it with show dummy rule
Disabled show dummy rule
Disable again uPnP
A period of 3 days didn’t reoccur
My wife is calling me that it doesn’t work again.
I can’t restart the router every time i want to start the ps4…
I don’t know what else to do… listening to any suggestion
If you click “Quick Set in Winbox”, At the top dos any of the IP addresses look like, 10 or 172 or 192.168? If yes you have double NATed, You would need to setup a Public IP or setup a DMZ on the main router to your mikrotik device.
Replace 192.168.88.251 with your PS4 internal IP, For ports 53 and 80 are DNS and HTTP traffic and will have no effect on your NAT type (they don’t on mine anyway).
3rd reset both PS4 and the RB951G-2HnD and then hopefully you have it working but if not try downgrading to 6.37.4 bugfix where you find this in “Check For Update” section
I don’t see why that should cause an issue. My PS4 is using my MT as primary DNS, as is every other device on my network.
I would however setup a DHCP reservation from the DHCP server settings - makes troubleshooting easier (although my PS4 worked fine on dynamic IP).
Propagation of DNS settings from mikrotik to ps4 didn’t work.
And as a fact the only problem was that ps network wouldn’t connect and this could be from the lack of DNS settings.
I didn’t try to see after the restart of the router if the propagation of DNS configs would be propagated in this case 8.8.8.8 and 10.10.10.10 (i don’t know if this is the real scenario)
