Hi
i try to reproduce following situation from OpenWRT where i have 1 SSID and vlans are tagged based on wpa passphrase
config wifi-iface 'wifinet0'
option device 'radio0'
option mode 'ap'
option ssid 't-WIFI'
option encryption 'psk2+aes'
option key 'SomeUnusedPass'
option wmm '1'
option short_preamble '1'
option disassoc_low_ack '0'
option max_inactivity '120'
option isolate '1'
option disabled '0'
option ifname 'wlan0'
option macaddr '0e:03:99:00:01:01'
config wifi-vlan
option name 'vl2'
option network 'vlan2'
option vid '2'
config wifi-station
option key 'vlan2-test'
option vid '2'
config wifi-vlan
option name 'vl200'
option network 'vlan200'
option vid '200'
config wifi-station
option key 'vlan200-test'
option vid '200'
this is working as expected, every VLAN have its own password and when i connect station to AP, correct VLAN is assigned based on password
but, when i try to reproduce same in MT with capsman
# 2023-09-06 10:04:11 by RouterOS 7.11.2
# software id =
/caps-man configuration
add channel.band=2ghz-g/n country=hungary datapath.local-forwarding=yes mode=ap name=wifi2 security.authentication-types=wpa2-psk,wpa2-eap .encryption=aes-ccm .passphrase=SomeUnusedPass ssid=t-WIFI
add channel.band=5ghz-a/n country=hungary datapath.local-forwarding=yes mode=ap name=wifi5 security.authentication-types=wpa2-psk,wpa2-eap .encryption=aes-ccm .passphrase=SomeUnusedPass ssid=t5-WIFI
/caps-man access-list
add action=accept allow-signal-out-of-range=10s disabled=no private-passphrase=vlan2-test ssid-regexp="" vlan-id=2 vlan-mode=use-tag
add action=accept allow-signal-out-of-range=10s disabled=no private-passphrase=vlan200-test ssid-regexp="" vlan-id=200 vlan-mode=use-tag
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=wifi2
only the first entry from access-list is accepted
so password “vlan2-test” is working, vlan2 is tagged on wifi
but when i try to use second password “vlan200-test” i get wrong password error on client device
what is a proper way to have password based WIFI vlan tagging on MT ?
and, no, please, no radius
tnx in advance
