PTMP best solution
Dear Mikrotik people!
I have a problem! I need to setup 30 clients wds with one BS but this configuration give me some problems. I think the problem is with broadcast traffic.
I think that I can use route configuration but I ask you for other ideas.
Thanks!
Is there a reason you want to use WDS for 30 stations or are you flexible on that?
Thanks for yout reply rickfrey!
I can fleixble on that!
Just to verify the scenario, are you saying that you have just on Access Point with 30 clients that are connecting?
