Thanks Pukkita. I am somewhat of a Noob here. I have been reading alot in the forums. I am really looking for guidance on how best to set this up… I believe I may need to do a bit of tuning here… I did a similar PTMP install before back in January of this year in a sub-office in South Sudan using MikroTik AP Bridge: (OmniTIK-U5HnD) and 4 Station Bridges: (SXT 5HPnD) its been working great… Using NV2, simple setup… With the newer equipment released, we decided to go with mANTBox 15s as the Sector and 5 RBSXTG-5HPacD as the station bridges… I set it up basically the same way… With your experience, I just want to verify that I am setup correctly… These antennas - all of them - are in a single compound… The compound is not big… perhaps 150m x 200m I have done nothing with the power levels or any tuning at all… I can get you the Exports next week when I log in remotely… But at the moment. They have no generator power over the weekend (This is South Sudan…) But in the meantime… Here is basically the way I set them up… Perhaps it needs some tuning - no doubt…
Can I please ask you to suggest how you would config in this case? I am concerned about no IT Support on site and failure of the main AP Bridge (for example). Is there a better config that may address my issues - A Mesh for example? WDS?.. I will be on-site Nov. 10th. I want to make sure a solid solution before I depart… I’m sorry to reach out to you directly like this, but there is not really much guidance available in the Wiki on issues like this. Thanks Pukkita.
AP Bridge: mANTBox 15s: (1 Unit)
Power & Winbox Via Ether1
Accept Default Configuration
Update the Firmware
Remove Default Configuration - Reconnect to MAC Address
Wireless: Enable Wlan1, AP Bridge, 5GHzA/N, 20/40 Ce, Auto Frequency, nv2, All Chains, security enabled, passphrase humanity,
Bridge: “AP Bridge”, Add ports to it Ether1 & Wlan1 (transparently Bridge Layer2)
Set IP on AP Bridge - 10.0.90.XXX/24 10.0.90.0
Set Identity
Setup DNS (8.8.8.
Exit (Reboot) & Physically Connect to CRS
From terminal ping 8.8.8.8 + Google.com
Setup SNTP us.pool.ntp.org & pool.ntp.org Enabled-Unicast
Set Clock System-Clock
Click Log Button to ensure RB is right time
Set Admin Password
Perform a Backup BCK-MANTv1
Perform an Export from the root… export file=SCR-MANTv1
STN Bridge: SXT 5HPnD: (5 Units)
Update the Firmware
Wireless: Enable Wlan1, Station Bridge, 5GHzA/N, 20/40 Ce, Auto Frequency,
Bridge: “Station Bridge”, Add ports to it Ether1 & Wlan1 (transparently Bridge Layer2)
Set Identities & IP Addressing on STN Bridge
SXT-A 10.0.90.XXX/24 10.0.90.0
SXT-B 10.0.90.XXX/24 10.0.90.0
SXT- C 10.0.90.XXX/24 10.0.90.0
SXT- D 10.0.90.XXX/24 10.0.90.0
SXT- E 10.0.90.XXX/24 10.0.90.0
Setup DNS (8.8.8.
Exit (Reboot) - connect via IP
IP Neighbours
Set Admin Password
Perform a Backup eg. BCK-SXTv1
Perform an Export from the root… eg. export file=SCR-SXTv1
