For PTMP it’s essential to know if you want to provide to customers Internet only, or if you want to bridge the customers into one network. If you want to let the customers exchange files between each other, then this is going to exhaust your link, because the AP will perform heavy rx/tx operations in both sides. Therefore QOS and limits are important factor in PTMP, because the link is not dedicated to one CPE anymore. You may be well of installing MIMO 2x2 AP and leave SISO 1x1 for the CPE.
As per antennas you should look for low VSWR ratio. You should use a frequency that is optimal for all CPE’s. You will end up adjusting the transmit power of your AP to achieve best link conditions, and vice versa: you will adjust transmit power on CPE’s depending on how far they are located.
Sextant is good CPE, unless you install it on a crowded tower that is full of competitor devices operating in a similar frequency range.
Thanks for the answer
In this network im gonna give customers Internet and Voip services. they can’t share files between clients, all they clients are isolated.
This means that your links will use tcp extensively. tcp protocol requires a lot of CPU resources. pick your AP router based on the number of customers that you will have and based on the desired bandwidth that you want to offer.
If you have a handfull of customers then each RB with MIMO card will suit you. The more bandwith you need, the more expensive it gets and a RB435G may become your best choice - it has a fast cpu to handle the traffic and gigabit port.
If customers are in one direction use MIMO panels/sectors. If they are in multiple directions use two wireless cards in your RB but choose different frequencies for each link. If they are in all directions I recommend looking for a MIMO omni antenna - quite rare but already available.
Do you know or try some of this antennas? what can u tell me about them, in my opinion the ARCflex are the most suitable for me i need to cover 360 and 5km.
ARCFlex is not popular in my country and I have never come across it. I am wondering who can provide some feedback about these antennas? How durable are they, where are they produced? The 19-21 dbi version looks very solid to me and I would like to have one.
Be carefull with those ITELITE sectors because these are antennas in outdoor enclosure and they don’t seem to have connectors if you want to attach a second antenna. There is just one ethernet pigtail. If you are planning to buy 3 such antennas to cover 360 and you want to put a router in each of them that’s fine.
I don’t like AirMax Titanium because of the price and the SMA connectors.
We prefer antennas with enclosures. This separates radios to reduce interference und avoids coax cable runs. Dont use this cheap plastic outdoor enclosures.
For 5Ghz: Dbii F52N-PRO and R52Hn are standard. These two radios work well together. You have to calculate disconnects and link drops into your project but it usually happens only on links with obstacles or limited LOS. A short disconnect can mute your VOIP call for a few seconds, but it should not disconnect it. In this regard hardware is important, but key point that matters most is correct software setup and perfect installation. Therefore, if you are just launching a new network, I would recommend you to buy from your local distributor before ordering overseas.
Sextant - I don’t use it, but I believe it’s at least as reliable as SXT. Maybe someone else can say something more about it.
I have many SXT’s operating very well. the range depends on your AP of course. The SXT is what you would expect for the price. It performs well but lacks build quality and shielding. As a CPE it is fine and that is what it is designed for. An SXT has roughly the range of a nanostation M5,
UBNT devices are prettier and more rugged however, In my opinion, the SXT wins as it has the power of routeros on board.
And of course you get the backing of this forum. The Mikrotik community is one of the greatest bunch of guys on the planet
Sextants are basically rb711-5hnd routerboards hooked up to 18dbi dualpol antennas. In fact you can take rb out and use it as you want.Like all mikrotik rb’s they work as they are supposed to.
I still think there should be a bigger gap in antenna gain between sxt and sextant..
we are upgrading to:
AP = RB800 with 3 R52Hn cards
Poynting dual-pol enclosure with 60degree sector antenna
90 degree dual-pol Ubiquiti sector antennas
WaveGuard or RFArmor antenna shields
