I have few PtP links with SXT 5 ac
Once they are aligned how can I check link bandwidth ?
I usually do a test with BandwidthTest tool, but the results are very different if I use UDP rather TCP and trasmit vs receive vs both.
How should I set them ?
What is the real bandwidth a customer can achieve for its own applications (yes there are so many different ones…) between both lan sides ?
I finally gave up trying to get accurate (or even close to accurate) tests with the MikroTik bandwidth test software. I found a couple of other software packages that worked much better. One is even free: www.tamos.com. Download their Throughput Test software and try it. You’ll need to run the server on a pc on one end of the connection and the client software on a pc on the other end.
