PTP BETWEEN LHG5 AND DYNADISH 5
Hi all,
I try to make PTP link between LHG5 and DYNADISH 5 but it doesn’t working. Any advice to give me.
PS: I use Dynadish like bridge( ap bridge not working due to ROS license level) and lhg5 like station bridge.
It should work. Did you ever make a link before?
Check that the wireless settings on each end are compatible.
Does you station-bridge see the the bridge through wireless scan?
Hi thanks for reply.
Yes i’ve already make a link on past. Between two same antenna (LHG-LGH, QRT-QRT or QRT-QRT).
But never do it with different antenna
Sadly no.
Make sure you use the settings that were successful for you, but are compatible with both devices.
That should work just fine, could you post WLAN config’s export from both devices?
The link is either misconfigured or there are some hardware-related issues.
Regards,
M.
MASTER CONFIG
interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=5ghz-a/n country=no_country_set
disabled=no frequency=5440 frequency-mode=superchannel mode=bridge radio-name=
DYNADISH-MASTER scan-list=5400-5600 ssid=FAUCO0021 station-roaming=enabled
wireless-protocol=802.11
SLAVE CONFIG
interface wireless
disabled=no frequency=5440 frequency-mode=superchannel mode=statiojn-bridge radio-name=
LHG5-SLAVE scan-list=5400-5600 ssid=FAUCO0021 station-roaming=enabled
