PTP Bridge with LHG XL 5AC with Cisco Trunks on each side - Having Issues
Description
I cannot figure out this configuration. So far I have:
Configured Bridge 1 > Enabled VLAN Filtering > Assigned ether1 and wifi1 to Bridge 1> Added VLAN 392 and VLAN 346 to bridge tagging on all interfaces (bridge, ether1, wifi1)
Configured wifi1 interface on both sides and they seem to be connected
Root side configured as “ap” (there is no bridge option) remote side configured as “station bridge”
I feel like there is something I’m missing here. I created a new interface for VLAN 392 for mgmt of the Bridge and I can’t even ping it from a device on the same switch connected to access port vlan 392.
The port connected to to the bridge on the cisco side is set as trunk with allowed vlans 392 and 346 with Native VLAN 999. I intend for only tagged traffic to pass through these bridges. But thus far I can’t get normal network connectivity to any facet of this setup. Any ideas?
Show the configurations you made, with the export, after having cleaned it of sensitive data.
The "novel" of the configurations doesn't "tell" anything.
Instructions here:
