Currently I have link with 2 x SXTG 2HnD between Point A and Point B and I’m not satisfied (see attached picture).
Although devices show connection 48Mbit/104Mbit, real throughput is roughly 6Mbits (tx/rx signals are -75/-69).
I asume that the problem are treetops, with great foliage at the moment. Distance is approximately 800 meters, no obstacles apart from trees I mentioned. Cutting trees down is not possible, since they are not on my land.
Or maybe I expect too much out of SXTs ?
I may have a solution with middle point (again, see the picture attached):
There is LoS from both Point A (app. 700 meters) and Point B (app. 200 meters).
I was thinking of buying 4x LHG-5 and setting them up in following way:
- Point A: LHG-5 toward middle point
- Middlepoint: 2x LHG-5 connected with ethernet cable, aiming toward Point A and Point B
- Point B: LHG-5 toward middle point
Is this solution viable ? Will it work properly the way I described ?
Should I continue with LHG-5 or invest more (a lot more!) and get Dynadishes or QRTs ?
Is there any other viable solution ?
Connection is backbone between my two properties and it should be solid and permanent solution. Through it goes internet connection (2x 25/2Mbit VDSL connection, load balanced) and light network traffic.
Thanks for all advices !
