Hello, I have two SXT Lite5 CPE and want ptp connection between them. Distance is 11-14km with clear los. How much bandwidth can I get? Can you send optimal configuration for that situation? I want link to be very reliable and 7-10mbps throughput.
Ciao,
see this good guide from http://www.wirelessinfo.be/index.php/mikrotik/pages/omnitikpp
The guide uses other devices but can also be applied to two SXT level 3, have a nice day cetalfio
It wont work for 11-14km. You need something bigger.
If the area is not disturbed the SXTs are able to handle that distance.
The best thing for a low cost P2P is to choose two Sextants http://routerboard.com/RBSEXTANTG5HPnD
cetalfio
