I need to aggregate two wireless PTP links, connected through a WDS bridge, to get more bandwidth. I’m using two RB1200s. I’ve read discordant opinions in many forums. What do you think is the most performant solution? Bounding, maybe?
Thanks in advance.
Is the traffic symmetric ?
As Wireless is half duplex consider using OSPF to send upstream up one link and downstream on the other.
It also gives good failover.
http://wiki.mikrotik.com/wiki/Setup_Dual_Wireless_Link_with_OSPF
If the post was helpful please give Karma
Unfortunately I can not use a link to the upstream and one downstream for each radio but will have to tx-rx.
