Hello to all
While I have inactivation by Bridge (AP) feature WMM, on the side of the station It seems as enabled !
Why?
Hello to all
Why?
See wireless / advanced on the station. Disable wmm there too.
on the station is disable!
/interface wireless set wlan1 wmm-support=disable
Then it might be a bug. Send supouts from both devices with description to support. They will tell you.
WMM support should be evident in a wireless packet capture. Check the beacons and probes between the devices and look for the IE (information element) for WMM.
I have observed with MikroTik products that when 802.11n is selected, WMM is enabled regardless of the configuration setting. If b/g is selected, then the configuration controls, as verified by the presence or absence of the WMM IE in the beacons.
Do you have n support enabled?
Yes is enabled
