ptp qrt 5ac 12.1 km
hi
i wanna make ptp 12.1 km and find pic to see i it possible to move the highest difference is high ? please advice
It’s stated at the calculator, link it’s possible, but you’ll need an outrageously high tower (>70m height) to mount the Tx device.
Either that, or use four devices to create 2 PTPs.
First PTP will clear the elevation by Rx’ing at the edge; this first PTP Rx radio will be wired to second PTP back to back, which will transmit to the final Rx.
70 meter really high :confused:
i think the best way is to make it on 4 devices ptp in two locations , but which ptp devices you recommend to me ?
i appreciate your help
regards
what bandwidth do you need?
sorry i didn’t understanding you ?
What do you need?
2Mbit
10Mbit
50Mbit
100MBit
200 mgbs but
200Mbps is going to depend on available spectrum, contiguous free 40MHz-50MHz minimum required.
Suitable devices for this in order of preference:
  • netmetal (dual chain) + mANT30-PA
  • netbox + mANT30-PA
  • QRT ac
  • DynaDish
Hello good day, I’m planning to connect 2 sites which has an estimated distance of 13.5km. May I ask what would be the best MikroTik Wireless System to uses for PTP connection? I have in mind but I dont know if this will work?
  1. Mant 30 PA
  2. Netbox
  3. Sleeve kit Cover
Thank you in advance for those who can answer me :slight_smile:
