Have a PTP setup with XR5s. Both sides set as bridge and using WDS. Do you think there is a need for extra security like WEP? Each side should only allow the other MAC address to communicate right?
You could go with WPA2.
WEP is a waste of time…
Craig
So you would say I need some type of extra security right?
yes, choose WPA or WPA2. i do not see any other possibility in your situation
