anyone running L11UG-5HaxD as PtP? If yes, what antenna are you using for long distance?
Thank!
Thank!
According to the user manual, You can set up the PtP bridge mode using QuickSet menu and choose your country, antenna gain, and router password You can use the WinBox configuration tool to update the device and adjust other settings. BallSportsGear
For example: https://rfelements.com/products/ultradish
