hello guys, i have a cable link with 256kbps\1mbps when i try the link on windows i got the full speed but when i put the link on MT i got only the full upload rate but only 860 kbps for download is there any option in the interface that i miss prevent me from getting a full 1 mbps. best regards.
Im not sure, but check the MTU settings…
You may be getting some fragmentation…
thank you for ur reply MTU set to 1500 , what it should be ? more or less best regards.
