Hi Experts…!!!
I want suggestions on how to restrict a set of static public ip address e.g(216.154.70.44,91.56.65.7) only to access the router interface.
Can anybody tell me how to do this via CLI or GUI interface.
The router version I am running is 6.17.
techspec90:
Hi Experts…!!!
On winbox / webfig / cli go to ip/services and for each service specify one or more “available from” address/ip pool
Thank You so much for your reply…
Can you tell me if I want to define pool what would be its syntax its showing 0.0.0.0/0 by defualt.
Thanks…
If you have one pool of IP from where you want access, use sytax like 80.80.80.0/23 (80.80.80.0 → 80.80.81.255)
If you have multiple pool or multiple single IP or both of them, you can use syntax like:
80.80.80.0/23,90.90.90.90,70.70.70.127/25,50.50.50.50
Great suggestion.
Does anyone know of a script available that would populate the “available from” field with an ip address fetched from dyndns or similar service?
I have several remote Mikrotik boxes that I maintain from a router that has a dynamic IP address. It would be great if I could limit the remote login attempts to just my admin machines.
Thanks.
