Public IP Issue
Dear All
I have Successfully configured PIP mapping using NMap and dst-nat
The issue i have now is that when the clients i assigned the PIP to searches for IP it shows my router IP instead of the PIP assigned to them
Today i got an email from my isp saying
Subject: email abuse report for 41.xxx.xxx.xxx (noreply)
Date: Wed, September 19, 2012 7:04 am
To: xxxxxxxxxxxxxx@xxxx.com
This is an email abuse report for an email message received from IP
41.xxx.xxx.xxx on Wed, 19 Sep 2012 02:00:39 +0200.
For your convenience this report uses the "ARF format" as defined by
RFC 5965. For more information about this format please see
http://tools.ietf.org/rfc/rfc5965.txt.
You'll find a copy of the offending message's headers at the end of
this complaint. If you have any questions, please include our refrence
number xxxxxxxxxx in your answer.
IT was showing my own IP without showing as assigned i wont be able to trace where its from
Kindly assist
Azeez
I’m not sure what you are looking for? Are you looking for the private IP address of the guest that is downloading illegally? If so, you’re not going to get it if you are NATing their traffic so they can get out to the internet, at least not without having a one-to-one NAT for each private IP.
If you really need to keep a log of who is going to what sites and using what services, look into netflows for logging and tracking that traffic.
Dear Feklar
Thanks for your post will look into it now
However the link http://forum.mikrotik.com/t/how-to-assign-a-public-ip-to-use-for-an-ip-block/53858/1 answers some of my questions too
Will get back to you should in case i get stuck
Pls do you have any in mind??
This is the manual for netflows:
wiki.mikrotik.com/wiki/Manual:IP/Traffic_Flow
You’ll need a collector to gather and inspect the traffic for you. There are many open source and closed source options there depending upon the feature set that you need and what you are looking to do. On the open source side I’ve played with Ntop, NFsen, and Cacti. NFsen is the only one that has been specifically designed for netflows however.
