Hello everyone. please, I have a preocupation, i’m a beginner with Mikrotik.
I have set a pptp vpn between two sites A (192.168.2.0) and B (192.168.1.0) which works very well,
but I want to go through the internet to reach a machine from my local site, ie network B, as ip public: port → pptp vpn → local network machine.
for example 156.202.X.X:8963 → pptp vpn → 192.168.1.32:80
I tried many indications without success. thanks for the help.
My routers are RB2011UiAS-2HnD
Can you ping the PC you want to access from the MikroTik router on site A?
If you can then you should just have to setup port forwarding as follow:
add chain=dst-nat in-interface= protocol= dst-port= action=dst-nat to-addresses= to-ports=
Hello Sarel0092,
thanks for your responding and sorry for the delay. Yes, each machine ping other, and i have already done this configuration, your configuration, but still not working.. ![]()
Please help, thanks!
