i have this Structure ESXI in Cloud installed Router OS on it.
get from the server company 400 Public IP . i want to do the following :
1 router board used as 2.
so my customer have already internet connection without static IP i want them to surf internet with the static IP from my Cloud.
i CAN config the Cloud Router in ESXI as PPPoE Server to give internet and Static IP but in this way i need 2 Routers by my Customer , 1 to connect over VPN (L2tp) to the Cloud Router and second to Connect to PPPoE so i will diagram it :
CLoud Router in ESXI ---------|L2tp|----------|Mikrotik1 for L2tp Connection|-----------|Mikrotik 2 for PPPoE|
in this way it work as i need and customer behind mikrotik 2 have Static Ip and can Surf internet from my Cloud Router but as i said it need 2 Routers for that.
can i do the same diagram with only 1 mikrotik installed by the customer ?? i tried on mikrotik 1 the following: ether 1 Wan connection by the customer L2tp connection and ether 2 in bridge , a Lan cable from Ether 2 to Ether3 and then PPPoE Client on Ether 3 . here i can get both Tunnels working PPPoE and L2tp but customer cant surf internet and Tunnels after few Minutes stop Working…
so if there is no way to use 1 mikrotik to get L2tp and PPPoE on same mikrotik . i am willing to build for the customer his own mikrotik in the Cloud Server and i know that there is a way were i can connect the 2 Router with L2tp and Get Routing in Customer Router Board to surf over the L2tp IP and not over his own Dynamic Ip .
how to do This please..
T
thank you
sorry for my bad english ![]()
