public ip thru internal access
Hello all
I’m playing my mikrotik router to forward traffic, now i have my ip cam which is the ip add is 192.168.100.20 and the port is 8001.
  1. if im in internal network i use this in browser 192.168.100.20:8001 it works without any problem
  2. if im in outside i use my public ip to forward base on dst-nat something like this publicIP:8001 it works without any problem
  3. now this is the problem if im internal network i try this publicIP:8001 it does not work.
please help me how to trick this kind of setup.
Myron
please post your firewall, nat, ip and route settings
Hi this is my simple setup
add address=192.168.99.1/24 broadcast=192.168.99.255 comment=ether3 disabled=no interface=ether3-local network=192.168.99.0
add address=192.168.100.1/24 broadcast=192.168.100.255 comment=PMS-local disabled=no interface=PMS-vlan network=192.168.100.0
add address=192.168.101.1/24 broadcast=192.168.101.255 comment=OFFICE-local disabled=no interface=OFFICE-vlan network=192.168.101.0
add address=192.168.102.1/24 broadcast=192.168.102.255 comment=HOTSPOT1-local disabled=no interface=hotspot-vlan1 network=192.168.102.0
add address=192.168.103.1/24 broadcast=192.168.103.255 comment=HOTSPOT2-local disabled=no interface=hotspot-vlan2 network=192.168.103.0
add address=192.168.104.1/24 broadcast=192.168.104.255 comment=HOTSPOT3-local disabled=no interface=hotspot-vlan3 network=192.168.104.0
add address=xxx.xx.xxx.211/24 broadcast=xxx.xx.xxx.255 comment=cable_pldt disabled=no interface=ether1-gateway network=xx.xx.xxx.0
add action=passthrough chain=unused-hs-chain comment=“place hotspot rules here” disabled=yes
add action=masquerade chain=srcnat comment=overall_nat disabled=no out-interface=ether1-gateway
add action=dst-nat chain=dstnat comment=“china >>>> boracay” disabled=no dst-address=xxx.xx.xxx.211 dst-port=2600 protocol=tcp
to-addresses=192.168.100.10 to-ports=2600
add action=dst-nat chain=dstnat comment=cctv_forward disabled=no dst-address=xxx.xx.xxx.211 dst-port=8001 protocol=tcp to-addresses=
192.168.100.20 to-ports=8001
add action=dst-nat chain=dstnat comment=“” disabled=no dst-address=xxx.xx.xxx.211 dst-port=8002 protocol=tcp to-addresses=192.168.100.21
to-ports=8002
add action=dst-nat chain=dstnat comment=“” disabled=no dst-address=xxx.xx.xxx.211 dst-port=8003 protocol=tcp to-addresses=192.168.100.22
to-ports=8003
add action=dst-nat chain=dstnat comment=“” disabled=no dst-address=xxx.xx.xxx.211 dst-port=8004 protocol=tcp to-addresses=192.168.100.23
to-ports=8004
add action=masquerade chain=srcnat comment=“hotspot1 masquerade” disabled=no src-address=192.168.102.0/24
add action=masquerade chain=srcnat comment=“hotspot2 masquerade” disabled=no src-address=192.168.103.0/24
add action=masquerade chain=srcnat comment=“hotspot3 masquerade” disabled=no src-address=192.168.104.0/24
add action=redirect chain=dstnat comment=pms_proxy disabled=yes dst-port=80 in-interface=PMS-vlan protocol=tcp to-ports=8080
add action=redirect chain=dstnat comment=pms_proxy disabled=yes dst-port=80 in-interface=OFFICE-vlan protocol=tcp to-ports=8080
add action=drop chain=forward comment=worms disabled=no dst-port=137-139 protocol=tcp
add action=drop chain=forward comment=“block rules” disabled=no in-interface=hotspot-vlan1 out-interface=PMS-vlan
add action=drop chain=forward comment=“” disabled=no in-interface=hotspot-vlan2 out-interface=PMS-vlan
add action=drop chain=forward comment=“” disabled=no in-interface=hotspot-vlan3 out-interface=PMS-vlan
add action=drop chain=forward comment=“” disabled=no in-interface=hotspot-vlan1 out-interface=OFFICE-vlan
add action=drop chain=forward comment=“” disabled=no in-interface=hotspot-vlan2 out-interface=OFFICE-vlan
add action=drop chain=forward comment=“” disabled=no in-interface=hotspot-vlan3 out-interface=OFFICE-vlan
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=“Port scanners to list "
disabled=no protocol=tcp psd=21,3s,3,1
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=“NMAP FIN Stealth scan”
disabled=no protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=“SYN/FIN scan” disabled=no
protocol=tcp tcp-flags=fin,syn
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=“SYN/RST scan” disabled=no
protocol=tcp tcp-flags=syn,rst
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=“FIN/PSH/URG scan” disabled=
no protocol=tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=“ALL/ALL scan” disabled=no
protocol=tcp tcp-flags=fin,syn,rst,psh,ack,urg
add action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w chain=input comment=“NMAP NULL scan” disabled=no
protocol=tcp tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
add action=drop chain=input comment=“dropping port scanners” disabled=no src-address-list=“port scanners”
add action=drop chain=input comment=“drop ftp brute forcers” disabled=no dst-port=21 protocol=tcp src-address-list=ftp_blacklist
add action=accept chain=output comment=”" content=“530 Login incorrect” disabled=no dst-limit=1/1m,9,dst-address/1m protocol=tcp
add action=add-dst-to-address-list address-list=ftp_blacklist address-list-timeout=3h chain=output comment=“” content=
“530 Login incorrect” disabled=no protocol=tcp
add action=drop chain=input comment=“drop ssh brute forcers” disabled=no dst-port=22 protocol=tcp src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist address-list-timeout=52w2d chain=input comment=“” connection-state=new
disabled=no dst-port=22 protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 address-list-timeout=1m chain=input comment=“” connection-state=new disabled=
no dst-port=22 protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 address-list-timeout=1m chain=input comment=“” connection-state=new disabled=
no dst-port=22 protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 address-list-timeout=1m chain=input comment=“” connection-state=new disabled=
add action=drop chain=forward comment=p2p disabled=no p2p=all-p2p
add action=drop chain=input comment=“block proxying in outside” disabled=no dst-port=8080 in-interface=ether1-gateway protocol=tcp
add action=accept chain=forward comment=rdp disabled=no dst-port=3389 protocol=tcp
add action=accept chain=forward comment=“brother printer port” disabled=no dst-port=54921 protocol=tcp
add action=accept chain=forward comment=“” disabled=no dst-port=54925,54926 protocol=udp
add action=accept chain=forward comment=ICMP disabled=no protocol=icmp
add action=accept chain=forward comment=“mail, pop3” disabled=no dst-port=25,26,143,110,465,995,2525,587,993 protocol=tcp
add action=accept chain=forward comment=HTTP disabled=no dst-port=80,81 protocol=tcp
add action=accept chain=forward comment=HTTPS disabled=no dst-port=443 protocol=tcp
add action=accept chain=forward comment=MSN disabled=no dst-port=1863,6891-6900,7001 protocol=tcp
add action=accept chain=forward comment=“” disabled=no dst-port=6901 protocol=udp
add action=accept chain=forward comment=“ventrillo and mumble” disabled=no dst-port=4346,64738 protocol=tcp
add action=accept chain=forward comment=“vonage " disabled=no dst-port=10000-20000 protocol=udp
add action=accept chain=forward comment=”" disabled=no dst-port=5050,5060-5063 protocol=udp
add action=accept chain=forward comment=“” disabled=no dst-port=123 protocol=udp
add action=accept chain=forward comment=“” disabled=no dst-port=80 protocol=udp
add action=accept chain=forward comment=SSH disabled=yes dst-port=22,23 protocol=tcp
add action=accept chain=forward comment=eve-online disabled=no dst-port=26000,6112 protocol=tcp
add action=accept chain=forward comment=winbox disabled=no dst-port=8291 protocol=tcp
add action=accept chain=forward comment=mirc disabled=no dst-port=6665-7000 protocol=tcp
add action=accept chain=forward comment=“streaming server” disabled=no dst-port=8000 protocol=tcp
add action=accept chain=forward comment=yahoo_messenger disabled=no dst-port=5050,5000-5001,5100 protocol=tcp
add action=accept chain=forward comment=“” disabled=no dst-port=5000-5010 protocol=udp
add action=accept chain=forward comment=teamspeak disabled=no dst-port=9987 protocol=udp
add action=accept chain=forward comment=“google talk” disabled=no dst-port=5222,5223 protocol=tcp
add action=accept chain=forward comment=“zynga poker” disabled=no dst-port=9339 protocol=tcp
add action=accept chain=forward comment=“china stock exchange” disabled=no dst-port=7708-7709 protocol=tcp
add action=accept chain=forward comment=“taiwan webmail” disabled=no dst-port=3000 protocol=tcp
add action=accept chain=forward comment=“mikrotik remote support” disabled=no dst-port=1122 protocol=tcp
add action=accept chain=forward comment=dns disabled=no dst-port=53 protocol=tcp
add action=accept chain=forward comment=“” disabled=no dst-port=53 protocol=udp
add action=accept chain=forward comment=FTP disabled=no dst-port=20,21 protocol=tcp
add action=accept chain=forward comment=“” connection-state=established disabled=no
add action=accept chain=forward comment=“” connection-state=related disabled=no
add action=accept chain=forward comment=cctv_cam disabled=no protocol=tcp src-port=8001-8005
add action=drop chain=forward comment=default_drop disabled=yes
/ip firewall mangle
add action=mark-connection chain=prerouting comment=“torrent user” disabled=no new-connection-mark=torrent_user p2p=all-p2p passthrough=
yes
add action=mark-packet chain=prerouting comment=“” connection-mark=torrent_user disabled=no new-packet-mark=torrent passthrough=yes
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
http://wiki.mikrotik.com/wiki/Hairpin_NAT
