not really recommended and possibly not supported by the other isp.
if you have a static ip it might be possible to route a subnet or even a single ip to your static ip, but even this is rarely supported by the most isps.
the best and simplest would be getting your isp to route you a subnet like a /29 to your dsl-connection. this will cost you a bit but is practically the only and best option.
