I don’t think I’m in a unique situation, but I’ll be damned if I can figure it out.
My ISP gave me two class C’s. We’ve currently got a slew of routers with private networks and we’d like to distribute these public IP’s to the private clients while still keeping the routers private.
I don’t even know the first step in doing something like this. I’ve been working with MT for 3 years, but this is a totally new situation for me.
Minimalistic layout of our network:
PUBLIC --> MT---->MT--->Clients
^----->MT--->Clients
^----->Local Network
At the moment, all of our routers have static private IP’s and are statically routed. They all give out private IP’s via DHCP.
Where do I even start on something like this?
You just have to route your subnets through your local routers, and just be aware to void NAT for the public subnets.
regards
Faton
Sorry for my newbnes…but how exactly do you do that?
My public MT is 66.76.60.154
My two Class C’s are 208.180.93.0/23
I don’t even know how to set up the public MT to accept stuff from the public IP addresses on the LAN
I tried to set up a PC with a public address and was told by Windows that there was an IP conflict.
Thanks,
Jay
Probably your ISP has routed this public subnet 208.180.93.0/23 via 66.76.60.154, what you can do is that you can divide in smaller prefixes this /23 subnet and route via your different routers. For example if your other routers connects directly to this first router, than use e.g. 208.180.93.0/28 for connecting the routers and rest just route through. like: ip route add dst-address=208.180.93.32/27 gateway=208.180.93.2 (one of the routers connected to 208.180.93.0/28).
Regards
Faton
Would there be any way to do this in a way that the MT addresses remain private?
Thanks,
Jay
yes, just route public subnet via private IPs of your routers.
Don’t forget to avoid NAT for public subnet.
