Ive been playing with mikrotik for a short time and I havent had much luck
Currently I have a 133c3 with level 3 and a 133 routerboard with level 4
I have configured the 133 as a ap bridge and the 133c3 as a station
I defined the interface wlan1 as 192.168.16.1/24 and the local lan ip as 192.168.30.55
the radios connect and i can mac-ping and mac-telnet each other however when i ping from my PC (with route added to the 16 network via 192.168.30.55) i get nothing
Pinging 192.168.16.5 with 32 bytes of data:
Reply from 192.168.30.55: Destination host unreachable.
192.168.16.5 is my laptop plugged into the ethernet on the AP which cant ping 192.168.16.1
I can however ping 192.168.16.1 from my pc on 192.168.30 network
Pinging 192.168.16.1 with 32 bytes of data:
Reply from 192.168.16.1: bytes=32 time=1ms TTL=64
Reply from 192.168.16.1: bytes=32 time<1ms TTL=64
I thought it may be a license issue so i checked and this is what i got
software-id: “-”
upgradable-to: v3.x
nlevel: 3
features:
So after doing some reading here i checked the package list and found “routing” wasnt enabled.. so i enabled it on both units and rebooted.. still nothing
I figure im doing something wrong so any help would be appreciated and will save my sanity!!
I didn’t completely understand your network arrangement, but I think the problem is with nat. You’re trying to access (ping) 192.168.30.x from 192.168.16.x which means traversing subnets. Of course pinging 192.168.16.1 from 192.168.16.5 shouldn’t be a problem.
Like surfertim said, you can achieve this by bridging wlan and ether1.
Otherwise, a more elegant way is by specifying srcnat and dstnat rules that ensure ip addresses are properly translated between those two networks anytime you try pinging across them. http://www.mikrotik.com/testdocs/ros/3.0/qos/nat.php
