I know this could sound silly, but, over the years, moving equipment around… I managed to lose the mounting ring of a cAP AC that’s still very much a good device, would have wanted to mount it to the ceiling outside instead of having it face up on furniture… but seems I can’t find the mounting ring anywhere in my mess.
Is it possible to purchase it separately, directly or through a vendor ?.. it’ll probably be more expensive in posting than the plate itself but well… WAF is better
The part # is 27857, some can be found online in the UK.
But you can also 3d print one (or have It printed).
Something similar (but for the Cap, so needing to be modified in measures to fit the AC): https://www.thingiverse.com/thing:6394351
Actually, if you adopt this simplified triangular shape it is quite easy to make one from a piece of scrap tin.
I don’t have an FDM anymore and my resin printer has been stashed over a year ago, lost the reflex to look up on thingiverse! nice one ! might go the route, I do have thin steel plates and steel scissors
