Purpose of using Bridge for CAP
I have a CAP connected to CAPsMAN and setup per the wiki, everything is working in tunnel mode.
I would like to know why on the CAP we need to add ether1 into the bridge, can we not just use ether1 (without a bridge) for tunnel mode?
I am planning to convert the CAPsMAN to use VLAN mode, would I need to use a bridge on the CAP in that case?
add admin-mac=B8:69:F4:D5:23:D3 auto-mac=no comment=defconf name=bridge protocol-mode=none
/interface wireless
# managed by CAPsMAN
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n channel-width=20/40mhz-XX country=no_country_set distance=indoors frequency=auto frequency-mode=manual-txpower installation=indoor mode=ap-bridge \
    ssid=MikroTik-D523D4 station-roaming=enabled wireless-protocol=802.11
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=no_country_set distance=indoors frequency=auto frequency-mode=manual-txpower installation=indoor mode=\
    ap-bridge ssid=MikroTik-D523D5 station-roaming=enabled wireless-protocol=802.11
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
set discover-interface-list=*2000011
/interface wireless cap
set bridge=bridge discovery-interfaces=bridge enabled=yes interfaces=wlan1,wlan2
add address=192.168.1.11/24 comment=defconf interface=bridge network=192.168.1.0
set servers=192.168.1.1
add distance=1 gateway=192.168.1.1
/system identity
set name=AP-DOWN
/system ntp client
set enabled=yes primary-ntp=192.168.1.1
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
Simply because for put tunnel on ether1, you must use… a bridge!
What do you mean by tunnel mode ?
CapsMAN can be either in CapsMAN Forwarding Mode or Local Forwarding Mode…
In case Capsman Forwarding mode is used, the Cap interface will be automatically added to the Capsman’s Router Bridge Interface, not on your CAP, so on your Cap you could just use your ether1 without any Bridge…
However, in case you use Local Forwarding Mode, the Cap Interface will be automatically added to the CAP’s Bridge interface, so you must use a Bridge here…
I use capac without capsman, far easier to configure and works well.
I use ether1 as the incoming trunk port for my vlans ( guest wifi, home wifi, iot, wifi and media wifi).
Works great (note the capac gets an IP address on the home/trusted LAN since I dont use a management vlan)
I also setup eth2 as a separate IP address (and if not accessible attach a wire that leads to an accessible location) to enable access to the capac if anything goes funky on the bridge.
