PUSHOVER - ready MikroTik script to send messages
My bad. I forgot to add the “as-value” — that’s critical to returning the data for the string. So it should be “$[/interface/lte/monitor lte1 once as-value]”.
Hey Ammo, many thanks for changing this, but unfortunately this doesn’t work and I get no message at all. The clock and system names work, as I said in my previous examples. These are 1 line results, though.
e.g.
message="Mikrotik SXT Rebooted <b>nPushover</b> $[/system clock get time] $[/system identity get name]"
I’m wondering if it is because the output of LTE monitor has many line of info … that it is not escaping or processing the lines properly :confused:
Does this code work on your device pushover? or is there a multi-line output we could check?
It’s not the multi-line output per se. It the data type returned by “monitor” is a RouterOS array type. And one rule (which I forgot in my quick example of LTE monitor) is array cannot be interpolated, so a “:tostr” is needed. This will get rather ugly output, but should work:
$npushover ({
        user="private"
        token="private"
        message="Mikrotik SXT Rebooted <b>nPushover</b><br><pre> $[:tostr [/interface/lte/monitor lte1 once as-value]]</pre>"
        title="MikroTik SXTR"
        html=1
        sound="magic"
        priority=0
        url="https://192.168.x.1"
        "url_title"="MikroTik"
Alternatively, you can collect the LTE monitor BEFORE build the PUSHOVER message, and use invidudual data items from LTE monitor in the string, like this:
:global npushover
:local mdata [/interface/lte/monitor lte1 once as-value]
$npushover ({
        user="private"
        token="private"
        message="Mikrotik SXT Rebooted <b>nPushover</b><br><pre>$($mdata->"primary-band") sinr: $($mdata->"sinr") rsrq: $($mdata->"rsrq") rsrp: $($mdata->"rsrp")</pre>"
        html=1
        sound="magic"
        priority=0
Ammo. You really are a very clever person. Both work for me :smiley:
I have a question, not so much about pushover.
I use TheDude and pushover - and it worked perfectly up until version 7.6 - in notifications it was enough to call the function “$pushover message=“Service [Probe.Name] on [Device.Name] is now [Service.Status]”;” just like other scripts.
Unfortunately, in version 7.15 - 7.16 calling $pushover does not work - scripts are called but not pushover - maybe you have an idea to fix it.
Best regards.
I wrote for 7.15 that a bit cleaner, see npushover above.
But your issue may be permissions on RouterOS side… You likely have put the script in /system/script with “Do not require permissions” with “policy” and “test” rights to run /tool/fetch. I believe there should be some log about it but perhaps not.
policy - policy that grants user management rights. Should be used together with the write policy. > Allows also to see global variables created by other users (requires also ‘test’ policy)> .
test - policy that grants rights to run ping, traceroute, bandwidth-test, wireless scan, snooper, > fetch> , email and other test commands
(from https://help.mikrotik.com/docs/spaces/ROS/pages/8978504/User), which is linked from Scripting, referring to “etc” to mean Dude)
Note: > Only scripts (including schedulers, netwatch, > etc> ) with equal or higher permission rights can execute other scripts.
(from: https://help.mikrotik.com/docs/spaces/ROS/pages/47579229/Scripting#Scripting-Scriptrepository)
But permissions is what’s changed from 7.6.
It’s not a permissions issue.
On RouterOS in the terminal or in other scripts the $pushover function works - and the firmware version /7.6, 7.15, 7.16/ doesn’t matter, only calling the $pushover function/script in TheDude in version 7.15, 7.16 doesn’t work.
Well I do not use notification with Dude, so IDK. But I’m not sure your Terminal test is exactly same user context as Dude running a notification. I cannot say for sure, but when Dude run calls RouterOS… that’s more similar to netwatch (which uses a *sys user), than Terminal from a logged in admin user.
Best you can do is add debug logging and perhaps something shows up when Dude call pushover. Because if it works in Terminal it ain’t the script code itself, thus the theory on permissions - since there are not a lot of other options…
Does calling a more basic script work from Dude? i.e. one that does not use /tool/fetch or global variables…
In this form it works and that’s enough for me. Thank you.
/tool fetch mode=https url="> https://api.pushover.net/1/messages.json> " http-method=post http-data=“token=axxxxxxx&user=uxxxxx1&message=Service [Probe.Name] on [Device.Name] is now [Service.Status]” output=none;
No :global variables maybe… glad it works.
