Putty updated to 0.71
Our trusty Putty has been updated to version 0.71. A time ago a vulnerability was discovered and through the EU-funded bounty program a few more were shared.
The latest version can be downloaded from:
https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
Change log:
https://www.chiark.greenend.org.uk/~sgtatham/putty/changes.html
Where do I install the putty package on my winbox??
Putty is a 3rd party utility that runs on Windows. You use it to connect to the SSH server instance on the MikroTik.
Which is my point. Post it in the phucking putty forum.
Do you want me to start effing posting everytime there is a windows update, a linux update, a macos update, an avast update, etc etc etc…
I might as well post everytime I pop a zit, and pluck a nose hair. :wink:
Hey @msatter Thanks for posting the update. Love Putty! But I also use Winbox Termimal plus my favorite SecureCRT :slight_smile:
Hey @Anav Good morning to YOU and relax buddy you need some sleep :slight_smile:
Or a coffee LOL.
I use hyperterminal LOL.
I use putty for plumbing purposes. :wink:
Remember: sleeping is poor substitute for caffeine.
And yes, I have been hessitant to post it here. Putty has not directly fixed the vulnerability and had good explaination to do so. Putty is used by many, also here and thatwhy I posted about is.
Sleep helps me to solve problems and caffeine makes me run in circles around it and not solving the problem. Some problem can’t be solved and the you have learn with them.
@msatter pray tell how do you cool the SFP on your hEXs … got a pic?
Maybe best put(ty) in the Useful Articles Forum LOL.
It’s been almost two years since the last release and it has no auto update functionality, so I think the post is warranted.
Yes, and I have now only the one between the power cable and the SFP and used a round file to make slight indentation so that not to much force is put on the power connector.
When it is realy hot (sommer) I put a little fan it.
The temp. is on the moment 41C and the ambient is about 13 degrees in the closset.
http://forum.mikrotik.com/t/sfp-module-is-extremely-hot/117746/21
