Hi, i face some problems with wireless conections.
cAP AC - same situation with or without security (wpa2)
- 2.4 band works without problems
- 5 Ghz band do not allow some devices to connect
- can connect some windows laptops and some android phones(older android 5 or 6 or 7)
- can not connect one windows 10 laptop and some android phones (one android 7 and 8, 10)
- windows laptop is reconnecting in a loop
- android devices show (NETWORK_SELECTION_DISABLED_ASSOCIATION_REJECTION)
PWRLine AP - only with security on (wpa2)
- 2.4 Ghz band exact same problems like with 5Ghz cAP AC
The devices was succesfuly connected to another devices like hAP, tp-link routers, huawei routers
It is probably something with settings, but i could not find it.
Thank you in advance for any help
