Python API script command
I have successfully connected to mikrotik api using this python script:
After running it I access api cli to send commands to the router.
What I need is sending commands through the python script itself.
So after a succesfull connection, script sends the commands that I need.
How can I achieve that?
#!/usr/bin/python
import sys, posix, time, md5, binascii, socket, select
class ApiRos:
    "Routeros api"
    def __init__(self, sk):
        self.sk = sk
        self.currenttag = 0
    def login(self, username, pwd):
        for repl, attrs in self.talk(["/login"]):
            chal = binascii.unhexlify(attrs['=ret'])
        md = md5.new()
        md.update('\x00')
        md.update(pwd)
        md.update(chal)
        self.talk(["/login", "=name=" + username,
                   "=response=00" + binascii.hexlify(md.digest())])
    def talk(self, words):
        if self.writeSentence(words) == 0: return
        r = []
        while 1:
            i = self.readSentence();
            if len(i) == 0: continue
            reply = i[0]
            attrs = {}
            for w in i[1:]:
                j = w.find('=', 1)
                if (j == -1):
                    attrs[w] = ''
                else:
                    attrs[w[:j]] = w[j+1:]
            r.append((reply, attrs))
            if reply == '!done': return r
    def writeSentence(self, words):
        ret = 0
        for w in words:
            self.writeWord(w)
            ret += 1
        self.writeWord('')
        return ret
    def readSentence(self):
        r = []
        while 1:
            w = self.readWord()
            if w == '': return r
            r.append(w)
    def writeWord(self, w):
        print "<<< " + w
        self.writeLen(len(w))
        self.writeStr(w)
    def readWord(self):
        ret = self.readStr(self.readLen())
        print ">>> " + ret
        return ret
    def writeLen(self, l):
        if l < 0x80:
            self.writeStr(chr(l))
        elif l < 0x4000:
            l |= 0x8000
            self.writeStr(chr((l >> 8) & 0xFF))
            self.writeStr(chr(l & 0xFF))
        elif l < 0x200000:
            l |= 0xC00000
            self.writeStr(chr((l >> 16) & 0xFF))
        elif l < 0x10000000:
            l |= 0xE0000000
            self.writeStr(chr((l >> 24) & 0xFF))
        else:
            self.writeStr(chr(0xF0))
    def readLen(self):
        c = ord(self.readStr(1))
        if (c & 0x80) == 0x00:
            pass
        elif (c & 0xC0) == 0x80:
            c &= ~0xC0
            c <<= 8
            c += ord(self.readStr(1))
        elif (c & 0xE0) == 0xC0:
            c &= ~0xE0
            c <<= 8
            c <<= 8
        elif (c & 0xF0) == 0xE0:
            c &= ~0xF0
            c <<= 8
            c <<= 8
            c <<= 8
        elif (c & 0xF8) == 0xF0:
            c <<= 8
            c <<= 8
            c <<= 8
        return c
    def writeStr(self, str):
        n = 0;
        while n < len(str):
            r = self.sk.send(str[n:])
            if r == 0: raise RuntimeError, "connection closed by remote end"
            n += r
    def readStr(self, length):
        ret = ''
        while len(ret) < length:
            s = self.sk.recv(length - len(ret))
            if s == '': raise RuntimeError, "connection closed by remote end"
            ret += s
        return ret
def main():
    s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
    s.connect((sys.argv[1], 8728))
    apiros = ApiRos(s);
    apiros.login(sys.argv[2], sys.argv[3]);
    inputsentence = []
    while 1:
        r = select.select([s, sys.stdin], [], [], None)
        if s in r[0]:
            # something to read in socket, read sentence
            x = apiros.readSentence()
        if sys.stdin in r[0]:
            # read line from input and strip off newline
            l = sys.stdin.readline()
            l = l[:-1]
            # if empty line, send sentence and start with new
            # otherwise append to input sentence
            if l == '':
                apiros.writeSentence(inputsentence)
                inputsentence = []
            else:
                inputsentence.append(l)
if __name__ == '__main__':
    main()
