Q+85MP01D breakout cable
Hi everybody!
I’m new to network fabric equipment. Can somebody give a hint what cable should I use with Q+85MP01D module?
I need long (20m) breakout cable, and found one on aliexpress: https://www.aliexpress.com/item/1005001771922159.html
Will it suite? I’m confused by the description as it is stated there that it has “1x12 MTP/MPO Connector”: https://mikrotik.com/product/q_85mp01d
So I’m at loss if I can use aforementioned 1x8 cable
Thank you
