Hi all
this is my one post in the forum
my Q i have 2 line pppoe from the same ISP
and i want mix it with Microtic how can do that
for ex the 1 speed 1Mb
the 2 speed 1Mb also
i want get 2Mb can i do that
thaks
Hi all
thaks
If your ISPs pppoe server supports Multi link PPP, then you can combine both lines.
Yes support
how can i do that
please i want some one explain me please
MLPPP over multiple links allow to create a single ppp link over multiple physical connections. All PPP links must come from the same server (server must have MLPPP over multiple links support) and all PPP links must have same user name and password.
And to enable MLPPP you just need to create PPP client and specify multiple interfaces instead of single interface. Mikrotik RouterOS have MLPPP clent support starting from version 3.10. Presently there are no MLPPP server support available.
I am not sure what else you want explained. Make a PPP client like you usually would and specify both interfaces instead of just one.
That’s taken directly from the link I posted.
hey,
I trying just the same at themoment.
I have 2 DSL Lines with 16MBit down and 1 MBit up.
I used to observe about 13-14 MBit as max. downspeed on one single line in the past.
Now I combined the 2 lines with MLPPP on Mikrotik RB450.
PPPoE Client Interface → adding second interface.
Everything seems to be fine, 2 links are established.
But the downstream is not really faster. still around 14 MBit. Upstream is now 1.7 MBit (as to be expected)
do I have to set something up in addition? MTU or so?
