Hi evry one here iam asking about telent
if i want seutup mikrotik by telent
iwant the commends to
Change Mode
Change SSID
Change Fre
Change Band
Add Brighde
Add prots
Change Idenity
please if any one can tell me coze i want it now
thanks
Change Mode
Change SSID
Change Fre
Change Band
Add Brighde
Add prots
Change Idenity
thanks
What is telent? Have you read the manual pages related to the individual function groups?
sir iknow what telent if u have commends ok if not thnak u
Now it is clear.
You mean telnet ? Anyway it is simple, you connect to the router via telnet.
First you need to getting know the Mikrotik RouterOS layout.
For example if you would like to set an IP address for an interface you need to know where located is:
ip address add address=10.10.200.0/30 interface=wlan0 disabled=no
or if you would like to change wireless mode: interface wireless set 0 ( number of interface ) mode=bridge disabled=no
I think the Mikrotik’s interface is friendly, easy to use.
yeahhhh sir u r right thank u very much i treid and every thing ok now
thanks
