[Q] Default login for RoterOS + config more mikr. together
Hello.
I’m new to dude, but I want a little help.
I want to scan our network, but problem is, that snmp is turned off by default on mikrotiks and I really don’t want to enable it manually on each device in network…
So it doesn’t read data, also it doesn’t connect the devices together or more IP to one device.
I hope that it’s possible by access into RouterOS. But default login is set to admin and password empty.
Is possible to change this default login/pass, so dude will automatically connect to it after scan?
Or is possible to activate snmp on all devices in few steps?
Thanks :slight_smile:
Never mind, it doesn’t help me.
But is possible to configure more mikrotiks in one time threw dude?
Send some script or something similar to selected devices…
