Hi.
I’m hoping someone can shed some light on this for me
Suppose I have the follow
What I want to achieve, I was to q-in-q the vlans over VLAN2000 to the second switch.
As you can see, in the switch I have 2 clients (untagged/access) in VLAN 10, then because the switch cannot do q-in-q by itself, I want the HEX to do it.
So the clients come into the HEX on directly on the bridge interface.
On the hex I then create a vlan-10 interface that uses vlan-2000 as its master (to create the q-in-q) then I add vlan10 to the bridge.
Is that the correct way to do it?
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=ether1-gateway
add bridge=bridge-local interface=ether3-slave-local
add bridge=bridge-local interface=ether4-slave-local
add bridge=bridge-local interface=ether5-slave-local
/interface vlan
add interface=vlan2000-uplink l2mtu=1596 name=vlan10-qinq vlan-id=10
add interface=bridge-local l2mtu=1596 name=vlan2000-uplink vlan-id=2000
The problem is that the moment I bridge the VLAN’s I can no longer ping across the q-in-q link (before bridging, traffic passes normally via the q-in-q vlan)
add bridge=bridge-local interface=vlan10-qinq
