Have at the moment next problem:
Link operates at dual nstream, ~54/54 x2 @5ghz-a turbo
Signal strength ~ -55dbm
signal to noice ~ 40 db
lowering db (manual to 10,13,5 does nothing)
real traffic push ~ 4,6-6,1MB/s
both sides 2xR5h +F50 pro(dbii) similar card
If cards are changed to DBii F50 N-card (atheros N11)
Then, link connects RX CCQ almost 100% TX CCQ goes suddenly to 25%;
speed 130ht / 6Mbps (jumps for second to 130mbps, then back). very unstable
signal strength -18 ~ -30 dbm
signal to noice ~ 80! db
RX CCQ could change with TX CCQ it's baddnes, -> TX goes good, RX bad ; and backwords
Both sides dbii Atheros 11N cards; I have tried to put then work on 5800mhz, then 5200mhz same thing. Scanning/frequency usage -110 almost all..
Where could be "mistake"?
Oh, ROS4.14
