QEMU vm speed problem
Hello
I tried to create a simple stand in PNET labs. Mikrotik chr-7.14.2 is border router btween external network and PC.
After setup ip address, dhcp-server, dhcp-client and masquerade (all other settings is defaults). ping from PC to 8.8.8.8 successfully passed.
But when I trying to measure speed (on speedtest.net) it shows 0.5 Mbps download and 1 Mbps upload
If i connect PC directly to network, without router, it shows my internet sleed (90 mbps)
I also noticed numerous errors in stats:
pnet note settings:
What problem could there be here?
that is expected PNET/GNS3 is just for lab/simulation only what do you expect? and even it can route properly, CHR is limited to 1MB only if you don’t have a valid license, you can obtain a demo P1 license and try again if you are that persistent :slight_smile:
Hi!
Change the NIC-card emulation type from “e1000” to “virtio”.
