I am currently validating CRS125 switch for one of my project work. I am struggling to configure VLANs in the switch. Basically, i want to use port ether2 as customer side trunk port carrying vlan 101 and 102, port ether3 will be connecting with the provider network, which should add another outer vlan 1000 on top of the customer vlan 101 and 102.
I configure the switch as per CRS examples, but it doesn’t seem to be working. Especially, I don’t see port ether3 is really tagging anyting.
set [ find default-name=ether2 ] master-port=ether3
/interface ethernet switch ingress-vlan-translation> add customer-vid=101 new-service-vid=1000 ports=ether2 sa-learning=yes
/interface ethernet switch egress-vlan-tag> add tagged-ports=ether2 vlan-id=101
/interface ethernet switch egress-vlan-tag> add tagged-ports=ether3 vlan-id=1000
/interface ethernet switch> set bridge-type=service-vid-used-as-lookup-vid
Any help would be much appreciated.
