Hello Guys, I have confiured the next link.
http://mum.mikrotik.com/presentations/US09/megis_qos.pdf
all works great. each user uses the rate established in pcq queue .
I want to use web cahe
But If I enable web-proxy and send the traffic of port 80 redirect to 3128(proxy) all above doest work.
I saw in firewall/connections when the dst-nat rule (redirect) is disable, each connection has a connection-mark and works excellent, but if i enable the rule the next connections appears without the mark, and each user “jumps” the rate established in the parameter rate in the pcq queue.
How can i use the configuration of the link with proxy-cache.
Regards
